Rockers breaking
Re: Rockers breaking
Ich denke ein Stück Seil oder Schnur durch das Kerzenloch eingeführt, ordentlich nachgeschoben und dann den Kolben auf OT gebracht.
So hab ich es auch verstanden.Motorbremse hat geschrieben: ↑10.07.2024, 15:38 Ich denke ein Stück Seil oder Schnur durch das Kerzenloch eingeführt, ordentlich nachgeschoben und dann den Kolben auf OT gebracht.
Problem is, that the rope probably gets compressed as well, not giving you enough room to remove the wedges.
The tool you were talking about: Google ventilhalter s1230 matra. Then you'll get a picture of what it looks like.
is he using this one ?
https://www.edelschmiede.com/shop/werkz ... e-opel-cih
The Idea of using rope istead of compressed air is a good trick when there is no tools available, maybe you could use some elctrical wire. Unfortunately the more i think about your Problem the more i think take the head of.
Also mal ehrlich. Bevor ich das mache, leihe ich mir halt nen Kompressor....
I guess, a combination of the Tool @Joan linked would do the Trick combined with this one:
Gerade bei #Kleinanzeigen gefunden. Wie findest du das?
https://www.kleinanzeigen.de/s-anzeige/ ... pp_android
If you're interested, I can help you buying it.
Normaler Vorgang was ins Loch zu stopfen. Wäscheschnur eignet sich gut..
- xpbernardo
Hello again.
Yes the tool is the one in your posts. Couldn't get one here so yes, I putted the string inside the cylinder between the piston and the valves and turn it to TDC. The tool I was using for the springs was the edelschmiede. Problem was the fact that the spring were locked on the oil seal groove so the springs were very very compressed already. With small add-ons to the tool we reached success.
I already managed to get all the valves loose yesterday evening. Everything is in the right place now.
Tomorrow I'm going to mount new rocker studs, rockers and the new locking system for the rockers.
Happy days. I think....
Rekord 1900 Luxe Coupé 67
