Rekord C Coupe 67
xpbernardo
Re: Rekord C Coupe 67
Beitrag von xpbernardo »
Second foto just after removal from the car as it was
First after rebuilt by "specialist" althou I had to redo it because jet position inside were wrong etc.....But did it following the manual and matching part numbers now
Rekord 1900 Luxe Coupé 67
Der hat kein Umluftsystem bzw. keine Umluftschraube. Hat Vor und Nachteile. Bin schon beide gefahren. Im Prinzip kannst du da nur deinen Co Anteil auf 2% bei 850 U/min einstellen. Mehr ist da nicht zu tun...
Als Test kann man an den Zündverteilerausgang ein Unterdruckmanometer anschließen. Bei 750 U/min, indem man einfach mit der Drosselklappenstellung runter dreht, dürfen maximal 15mm/hg anliegen. Sonst zieht es deinen Verteiler zu früh in früh.
xpbernardo
Running pretty smooth now. And got to the conclusion that my new rotor and distributor cap are the wrong ones or not so good. Installed the old cap rotor and cables and voilà... A new car... 🤔
xpbernardo
My propshaft joint is destroyed and flew away in the street along with the locking "C"s that lock the propshaft to the diferencial. I can't remember if there was a set of locking plates there or not. Parts catalog only refers to commodore. Not rekord. Anyone can confirm this?
Thats annoying.!
There are locking plates for ordinary nusts. However if you use self locking nuts its fine without.
xpbernardo
Joan hat geschrieben: 15.07.2024, 17:19 Thats annoying.!
They were already there. Any recommended place to buy a good joint? Preferably with lubrication...
xpbernardo
Back from the third test ride. Joint overhaul is done . No vibration, no sounds.
The valve cover is still leaking. Noe only on the back of the engine. ELRING cork gasket, red high-temp gasket maker on the cover before putting the gasket and STILL leaking.... It goes all the way through the engine block to the floor when parked. Even in very small trips :shock:
Dein Ventildeckel ist verbogen. Besorg dir einen anderen Ventildeckel oder gleich einen Aluventildeckel.
xpbernardo
sable hat geschrieben: 28.07.2024, 14:40 Dein Ventildeckel ist verbogen. Besorg dir einen anderen Ventildeckel oder gleich einen Aluventildeckel.
I´ve a spare one that looks perfect. I´ll paint it and give it a go :wink:
xpbernardo hat geschrieben: 28.07.2024, 14:46
Erst probieren, dann lackieren. :wink:
Die Ventildeckeldichtung sollte bei einem intakten Ventildeckel ohne Dichtmittel abdichten.
Wenn du Dichtmittel verwendest, dann pebibel aufs entfetten achten und am besten einen Tag warten, bevor du den Motor startest.
xpbernardo
sable hat geschrieben: 28.07.2024, 14:57
I´ve done that. Waited 24h before starting the car again.
The old gasket had some red gasket maker also and the car never leaked....
Testing it before painting is a very good idea :mrgreen:
sable hat geschrieben: 28.07.2024, 14:57 Wenn du Dichtmittel verwendest, dann pebibel aufs entfetten achten und am besten einen Tag warten, bevor du den Motor startest.
Hab ich auch auf die harte Tour lernen müssen :-)
xpbernardo
"new" valve cover not leaking
And after a short circuit on the alternator and repair... It's home!
