Seite 11 von 21
Re: Rekord C Coupe 67
Verfasst: 07.01.2024, 11:14
von xpbernardo
the Brain hat geschrieben: ↑07.01.2024, 11:09
xpbernardo hat geschrieben: ↑07.01.2024, 09:52
Just to double check... Left springs are longer front and rear right? To compensate drivers weight.
I repainted the 2 pairs and marked them, but just to make sure.....
Nope. There is no difference between left and right Side. Front an rear are different.
well..in that case I have 2 of them with the same height and higer than the other 2 ...
Verfasst: 07.01.2024, 11:58
Wire thickness of the front springs Rekord C 12.5mm.
At the rear, the springs vary between 12.5mm and 14.3mm.
And the diameter of the springs is different. About 5mm.
So the upper rubber only fits into the axle beam at the front and only on the front springs. There is no rubber at the bottom front. The rear has a rubber at the top and bottom. When removed, the front springs should be longer than the rear ones. This is usually because they have to bear more weight and compress more when installed.
They should also have one more coil than the rear ones.
Verfasst: 07.01.2024, 12:43
von xpbernardo
the Brain hat geschrieben: ↑07.01.2024, 11:58
In that case I´ve the pairs mixed up. Good thing I checked before install. So I´ll join the 2 longer ones to the front and the other 2 that are smaller in the back.
Once again. THANK YOU again the Brain
Verfasst: 07.01.2024, 13:55
No Prob.
Test the rubbers. The front ones usually have the smaller diameter. Maybe the rears are longer for special use like AHK or more load.
From the Factory they are marked with colour.
Verfasst: 07.01.2024, 14:56
von xpbernardo
the Brain hat geschrieben: ↑07.01.2024, 13:55
No Prob.
Now you´re talking about the rubbers. Not the springs, right?
Verfasst: 07.01.2024, 22:18
Both Man. A rear Spring is too big to fix in
the axle with the correct rubber.
Verfasst: 08.01.2024, 12:38
von xpbernardo
the Brain hat geschrieben: ↑07.01.2024, 22:18
OK. Perhaps something went wrong in translation
So.. Front coils are longer but narrower than rear ones
Verfasst: 08.01.2024, 12:54
von opel68
Hätt ich doch besser in der Schule aufgepasst.
Übersetzen ist auch nervig
Aber wir helfen gerne
Verfasst: 08.01.2024, 13:42
von xpbernardo
Verfasst: 08.01.2024, 15:41
opel68 hat geschrieben: ↑08.01.2024, 12:54
....was ist an Copy-Paste nervig.....das ist ne Sache, die in Sekunden erledigt ist......
Verfasst: 08.01.2024, 19:03
von opel68
buckrodgers61 hat geschrieben: ↑08.01.2024, 15:41
Ja,hast ja recht
Verfasst: 08.01.2024, 19:04
opel68 hat geschrieben: ↑08.01.2024, 19:03
Ja,hast ja recht
…und wieder was helernt….Schule hört nie auf…
Verfasst: 08.01.2024, 21:21
Mit Copy Paste schreiben viele ihre Doktorarbeiten und werden später Bundespräsident. So kann das enden.
Verfasst: 08.01.2024, 21:43
von opel68
Jörg hat geschrieben: ↑08.01.2024, 21:21
Oha,dann verkauft Buck sein Rekord und sitz in der S Klasse hinten
Verfasst: 09.01.2024, 08:50
ihr habt irgendwie komische Gedanken....
